hata_3396041
Level 4
Level 4
First solution authored First like received 50 questions asked
Hello
I want to write the PSoC 6 HEX file created in the PSoC Creator project to another device.
Since PSoC 6 is dual core, HEX files are created in the M0 folder and the M4 folder respectively.
(A total of three HEX files have been created)
If I want to write with PSoC Programmer, should I write the HEX file in M4?
(Do I need both HEX files to write to PSoC6?)
Best Regards
Hayato
Rakshith
Hi @hata_3396041,
 Which is the device selected in the PSoC Creator project and which is the device that you are trying to program? I do not think this is allowed. Can you please let me know if you can change the device in the project?
Regarding your second question, I think this thread will help - PSoC dual cpu
Thanks and Regards,
Rakshith M B
Rakshith
Hi @hata_3396041,
Thanks and Regards,
Rakshith M B
Hello Rkshith
Thank you for your reply.
I understand that if I want to write with PSoC programmer, I can write M0 just by writing the HEX file in the M4 folder.
Best Regards
Hayato
