Graph Thermistor value
Taylor70
First solution authored 10 replies posted 50 sign-ins
Hi all
I am struggling with my CY8CKIT-062-BLE kit code example. What I am trying to do is graph on the EPD display the thermistor value, which I believe there is an example of
However I can't find this example code
Could anyone send a link if they know where this example code is?
Arpit_S
50 likes received 250 replies posted 100 solutions authored
Hi @Taylor70,
You can refer to https://github.com/Infineon/mtb-example-psoc6-emwin-tft-freertos Code example. This example demonstrates displaying 2D graphics on a TFT display using the emWin graphics library and the AppWizard GUI design tool in FreeRTOS. The application initializes the system peripherals and creates a task that cycles through demo images in response to button presses.
Thanks & Regards
Arpit Srivastav
Arpit_S
Hi @Taylor70
Can you please share which development environment are you using? Is it PSoC Creator or ModusToolbox?
Arpit Srivastav
Arpit_S
Hi @Taylor70,
Thanks & Regards
Arpit Srivastav
