I am trying to program the CY8CKIT-062-WIFI-BT kit using the KitProg from a CY8CKIT-059 PSoC 5LP Kit. The Kitprog has been separated from the PSoC 5LP stick. I am not using the WIFI-BT Kit's own Kitprog.
I am able to program the CY8CKIT-062-WIFI-BT successfully with a MiniProg4.
When trying to connect with the 5LP KitProg (v2.21), I receive the error "Given Target Method (6) is not supported!"
This error is not in the help manual.
- What does it mean?
- What is "Target Method (6)?"
Hi BeBl_4528851,
KitProg does not support PSoC 6 programming. You will need a KitProg3. Please refer to KitProg User Guide for the list of devices that it supports. You can also find the snapshot of the table below -
If avaiable, can you please try programming the device with KitProg3 and let me know if that works? You can refer the KitProg3 User Guide for further details.
Thanks and Regards,
Rakshith M B
Rakshith M B
Hi BeBl_4528851,
Thanks and Regards,
Rakshith M B
Rakshith M B
Thank you. I can successfully program with a KitProg3.
This error arose when working on porting HSSP code, at an interim step.
