Generating frequency
aliissa02
Level 4
Level 4
100 sign-ins 50 replies posted 5 likes given
I am trying to generate an output frequency of 6 MHz using a PSOC 6 prototyping board but every time I measure the output pin using an oscilloscope its only giving 1.5 KHz. I want to get 6 MHz when I measure the output pin. I have attached the project. Can anyone help please?
Thank you
PandaS
250 replies posted 100 solutions authored 5 likes given
Hi @aliissa02 ,
I believe that this issue is already being discussed in this thread https://community.infineon.com/t5/PSoC-6/Generating-frequency-PSOC-6/td-p/364661  and solved in https://community.infineon.com/t5/PSoC-6/Generating-frequency/td-p/364286
We will continue our discussion in the original thread and I will go ahead and lock this thread.
Thanks and Regards,
Sobhit Panda
Cypress Semiconductor Corporation
An Infineon Technologies Company
Len_CONSULTRON
Level 9
Level 9
aliissa02,
As explained in a previous post.
Len
aliissa02
Level 4
Level 4
Thanks for this. It is still not working. Its only reading 50 Hz which means no frequency being generated.
aliissa02,
Make sure you don't have a HW wiring issue.
Suggestion:  Push the output to a different pin.
Len
I did  that and still the same thing
PandaS
Hi @aliissa02 ,
Thanks and Regards,
Sobhit Panda
