aliissa02
Level 4
Level 4
100 sign-ins 50 replies posted 5 likes given
I am trying to generate an output frequency of 6 MHz using a PSOC 6 prototyping board but every time I measure the pin using an oscilloscope its not giving me the required frequency. I have attached the project. Can anyone help please?
Thank you
Rakesh_Patrudu
25 solutions authored 5 likes given 50 replies posted
Hi @aliissa02 ,
We have recreated the project on the same device that you are using i.e.; CYBLE-416045-02. We can obtain a 6Mhz output frequency. Please review the project file that I have included below.
Rakesh
Len_CONSULTRON
Level 9
Level 9
aliissa02,
You had some issues with your original code in main().
I made some simple changes with comments.
It now works.
Len
aliissa02
Level 4
Level 4
Thanks for your help. I tried measuring the output pin and its not giving 6 MHz. Its only giving 1.5 KHz.
Thank you
aliissa02,
You are correct.  The output at pin P9.5 is 1.526KHz.
This is because YOU set the PWM Period0 to 4096u
With an input clock of 6250KHz and the Period0 of 4096, your output is 6250KHz/4096 = 1.5258789KHz.
Simple math.
If you want an output of 6.25MHz I recommend the following changes:
Len
aliissa02
Level 4
Level 4
It is still not working!
Rakesh_Patrudu
Hi @aliissa02 ,
Rakesh
aliissa02
Level 4
Level 4
Its finally working. Thanks a lot!
