jacintal
10 sign-ins 5 questions asked 5 sign-ins
I am wondering if there would be a function/method to trigger auto-calibration for CSX when there's an apparent change in baseline capacitance (goes up from 1pF to 2.5pF for example)?
Thank you!
PandaS
250 replies posted 100 solutions authored 5 likes given
Hi @jacintal ,
Could you be specific on what you want to auto calibrate.
If you want to enable Auto Calibrate IDAC, following steps should do:
Go to CapSense Configurator-.>Advanced Tab-> CSX Settings -> Enable IDAC auto-calibration
If you are asking for a function which triggers the feature of sensor auto reset. Well you can always enable or disable it in the CapSense configurator.
Please go to CapSense Configurator -> Advanced Tab -> Enable Sensor Auto Reset
Warm Regards
Sobhit
PandaS
Hi @jacintal ,
Warm Regards
Sobhit
