Hi. I am trying to create a project using CY8CKIT-062-BLE PSoC 6 BLE Pioneer Board and connect FreeRTOS to it as described in the manual. But I am facing the problem of not understanding what kernel is selected in this project. I see in the bsp makefile that kernel BSP_COMPONENTS:=CM0P_BLESS is selected but when I add configuration file to my project with the right kernel, the project gives errors in another file from mtb_shared folder. Can you explain the logic of working with this kind of error?
And I keep getting this error Unresolved inclusion: "cy_utils.h". How can this be fixed?
Hi @Roman1 ,
Please refer to the thread.
"error Unresolved inclusion: "cy_utils.h"."
This is caused when the Eclipse indexer cannot find the header file you have included. This commonly happens when you have installed the library of that header file in a non-standard location. Please check where this header file is located in your project.
Let me know if this solves the issue.
Warm Regards,
Gautami J
This library is located in the folder mtb_shared, which is downloaded automatically when you create a project. I noticed that many files have this problem if they are outside the main project.
Hi @Roman1 ,
After adding this to the main project. Is it working properly on your end?
Warm Regards,
Gautami J
Hi @Roman1 ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Gautami J
An Infineon Technologies Company
