user_3899081
First like received
I am using opamp to amplify the ouput voltage from piezoelectric. Output from opamp will be the input for ADC. But I have an error to connect external resistor.
I don't know what i did wrong. Can you help me, please?
Thank you for your help,
Tita
RodolfoGL
250 sign-ins 5 comments on KBA First comment on KBA
You have to use the dedicated pins connected to the OpAmp. You can refer to the Design Wide Resources > Analog schematic view.
OA1:
Negative: P9[4]
Positive: P9[5]
Output: P9[3]
OA0:
Negative: P9[1]
Positive: P9[0
Output: P9[2]
RodolfoGL
OA1:
Negative: P9[4]
Positive: P9[5]
Output: P9[3]
OA0:
Negative: P9[1]
Positive: P9[0
Output: P9[2]
