error occurring in KEIL IDE which weren't shown when executed in PSOC creator. Not able to resolve the error either. attached is the image of the problem I am facing. please let me know where is this going wrong.
thanks
PSoC 6 MCU
Hi @niharika ,
We too observed the same errors when using ARM compiler 6 (as shown in the screenshot you shared above).
Can you please try the same procedure by installing ARM Compiler 5.
After installing the compiler, you have to change the compiler used in the Target tab as shown in the below image:
Try to build the project after this and let us know if you are observing any errors.
Alen
Hi @niharika ,
Can you share a screen shot of the about section under help which can be selected as shown below:
Alen
here is the screen shot
Hi @niharika ,
Alen
Will do . Thanks a lot!!
