magnus
10 replies posted First like given 25 sign-ins
After updating my project I cannot debug or program it anymore. My project was single core, I updated it to dual core and now the launches on quick panel are not working anymore.
I tried to re-generate the launches, erase all ".project" and ".cproject" (root, CM0 and CM4) and create again using "make eclipse" but nothing worked.
It shows this error:
This the MTB version MTB 3.0.0 build 2749
the command "make program" works, so I believe the issue is on Eclipse IDE.
thank you ,
Magnus
magnus
Hi  @Gautami_12 ,
I found the solution.
When I update the project from a "one core" to a "multi core" model - in my case I have both in different git branches - It doesn't recognize the new internal projects, you can see the icons for the projects are the "folder" type:
To fix I asked to re-generate launches, at this moment if I right click the folder it will show the option "Import as project"
Then I import CM0p and CM4 and everything works fine.
thank you for your help,
Magnus
Gautami_12
50 likes received 100 solutions authored 250 replies posted
Hi @magnus ,
This error has been documented in the release notes, please check if it helps:
Do you have any previous versions of ModusToolBox software installed on your pc?
Warm Regards,
Gautami J
magnus
Hi @Gautami_12,
I saw this solution, It didn't help in my case. I have MTB3.0 and MTB2.4 installed, the issue is on MTB3.0.
magnus
Hi  @Gautami_12 ,
Magnus
