PSoC™ 6 Forum Discussions
JCD
50 sign-ins 25 sign-ins 10 replies posted
Originally very normal, suddenly unable to download the code, the following is the console display info?
Started by GNU MCU Eclipse
Open On-Chip Debugger 0.10.0+dev-4.1.0.1058 (2020-08-11-03:47)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
adapter speed: 2000 kHz
adapter srst delay: 25
adapter srst pulse_width: 25
** Auto-acquire enabled, use "set ENABLE_ACQUIRE 0" to disable
cortex_m reset_config sysresetreq
Warn : SFlash programming allowed for regions: USER, TOC, KEY
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: FW Version = 2.0.0
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : KitProg3: FW version: 2.21.1005
Info : KitProg3: Pipelined transfers enabled
Info : VTarget = 3.328 V
Info : kitprog3: acquiring the device...
Error: kitprog3: failed to acquire the device
Info : clock speed 2000 kHz
Error: DAP 'psoc6.cpu' initialization failed (check connection, power, etc.)
Info : psoc6.dap: powering down debug domain...
Warn : Failed to power down Debug Domains
Rakshith
Hi @JCD
I believe the issue in this thread is the same as this thread -  Warn : SFlash programming allowed for regions: USER, TOC, KEY
We will continue our discussion in that thread and I will be locking this thread. Please let me know if it is a different issue.
Thanks and Regards,
Rakshith M B
Rakshith
Hi @JCD
Thanks and Regards,
Rakshith M B
