Hi All,
I am experimenting with the above and has problem when install cysecuretools using macOS terminal for example project "secure Blinky LED FreeRTOS". I have attachment the terminal log below.
Note: The log is when I run the "pip install -U cysecuretools" in macOS terminal.
Still, I get 1 error msg for same command executed in ModusToolBox project terminal window. Only difference in last few lines compared with attachment log.
"note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cmsis-pack-manager
Failed to build cmsis-pack-manager
ERROR: Could not build wheels for cmsis-pack-manager, which is required to install pyproject.toml-based projects"
In addition, I have error with the following commands. What do they do?
update-alternatives --install /usr/bin/python python /usr/bin/python2.7 1
update-alternatives --install /usr/bin/python python /usr/bin/python3.7 2
error is "zsh: command not found: update-alternatives"
I am running ModusToolbox_2.4.0.5972 and Python3.10.3
Also, Does anyone know how to set environment variables for the above so I do not need to retype these 3 commands every time I reboot the OS?
echo 'alias python=python3' >> ~/.bash_profile
echo 'alias pip=pip3' >> ~/.bash_profile
source ~/.bash_profile
Thanks and Regards
CW
Please close this thread. Problem resolved. It seems cysecuretools only support 32 bit python version. I manage get cysecuretools working after changing to version python-3.9.8-macosx10.9.pkg
Hi @chwaitang,
When you install ModusToolbox you should have cysecuretools already present in the MTB environment. You need not separately install cysecuretools again.
In addition to that, I believe you have Python 3.1 and Python 2.7. The minimum prerequisite is Python 3.6.
Rakshith M B
Hi Rakshith,
Thanks for reply. I am new to macOS. I did following in ModusToolbox terminal;
tangcw@Tangs-MacBook-Pro cm4_app % python --version
zsh: command not found: python
tangcw@Tangs-MacBook-Pro cm4_app % python3 --version
Python 3.10.3
So what is the version registered with ModusToolbox? How can I switch to version 3.10.3?
Please state step by step the way to do that if possible.
Otherwise can I uninstall ModusToobox and then re-install? I remember I did not install any Python app b4 ModusToolbox installation. I installed ver 3.10.3 later. Will that help?
Warm regards
CW
Hi Rakshith,
I have done:
1) full re-install of python ver 3.10.2
2) install pyenv and set global to ver 3.10.2
3) remove and reinstall of ModusToolbox_2.4.0.5972-macos-install.pkg
4) installed and added CMSIS Packs perspective in ModusToolbox
5) download and installed cypress CMSIS pack for device CYB0644ABZI-S2D44 for Secure Blinky LED FreeRTOS example in my CY8CKIT-064B0S2-4343W WiFi BT secure boot pioneer kit.
6) checked cysecuretools is not installed by default when installing ModusToolBox 2.4
7) run "pip install cysecuretools" in ModusToolBox terminal window
😎 The log attached below.
The error is Could not build wheels for cmsis-pack-manager, which is required to install pyproject.toml-based projects.
I am running ModusToolBox 2.4 on macOS Monterey 12.3
I can see no other way out of this. Please advise.
Warm regards
CW
In addition, I have upload zip archive of secure Blink example for you to see build error:
File "/Users/tangcw/mtw1/Secure_Blinky_LED_FreeRTOS/libs/TARGET_CY8CKIT-064B0S2-4343W/psoc64_postbuild.py", line 22, in <module>
from cysecuretools import CySecureTools
ModuleNotFoundError: No module named 'cysecuretools'
Pls advise how to overcome problem.
Warm regards
CW
Hi CW,
I tried it out on a mac device. As you said, cysecuretools is not installed by default on Mac. I missed that. However, I was able to get the cysecuretools working without any issue.
By default, the python version was 2.7 and so I used this command in the terminal -
pip3 install cysecuretools
This worked for me and I was able to get cysecuretools working and I confirmed this by running the command -
cysecuretools --help
I assume that you have tried the same and that did not work for you. Can you please run 'pip3 list' and share the list of modules so that I can compare it with mine?
Rakshith M B
Hi Rakshith,
tangcw@Tangs-MacBook-Pro cmsis-pack-manager-main % pip3 list
Package Version
appdirs 1.4.4
certifi 2021.10.8
cffi 1.15.0
cmsis-pack-manager 0.4.0
milksnake 0.1.5
pip 22.0.4
pycparser 2.21
PyYAML 6.0
setuptools 58.1.0
Warm regards
CW
Sorry,
this is latest list after i run pip install cysecuretools in Mac terminal. Result is failed build wheel for cryptography but can build wheel for CMSIS pack manager. Next I run pip install cysecuretools in ModusToolBox terminal and get error of fail build wheel for CMSIS pack manager but no mentioned error when build cryptography.
Below is the result list:
Package Version
appdirs 1.4.4
cbor 1.0.0
certifi 2021.10.8
cffi 1.15.0
intelhex 2.3.0
milksnake 0.1.5
pip 22.0.4
pyasn1 0.4.8
pycparser 2.21
pyelftools 0.28
PyYAML 6.0
rsa 4.8
setuptools 50.3.2
six 1.16.0
sortedcontainers 2.4.0
wcwidth 0.2.5
Pls advise
Warm regards, CW
Again sorry,
this is latest after running pip install wheel (I am not sure if it is this wheel)
tangcw@Tangs-MacBook-Pro cysecuretools-release-v3.1.0 % pip list
Package Version
appdirs 1.4.4
cbor 1.0.0
certifi 2021.10.8
cffi 1.15.0
intelhex 2.3.0
milksnake 0.1.5
pip 22.0.4
protobuf 3.20.0rc2
pyasn1 0.4.8
pycparser 2.21
pyelftools 0.28
PyYAML 6.0
rsa 4.8
setuptools 50.3.2
six 1.16.0
wcwidth 0.2.5
wheel 0.37.1. <----
But still same error. Attached log for running pip3 install cysecuretools from macOS terminal and ModusToolBox terminal.
See the difference of able to build wheel for CMSIS-pack-manager but fail build for cryptography but the other fail build for CMSIS-pack-manager.
Warm regards
CW
