Vivek_DiehlCont
Welcome! First question asked First like given
I am using Capsense Tuner with PSoC 6 using UART. First I used the evaluation board to test. It worked fine on evaluation board using Kitprog as USB to UART convertor.
But it is not working with FTDI chip and I am always getting connection to COM Port failed.error.jpg
Is it the problem of tool ?
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @Vivek_DiehlCont ,
Can you please let me know the UART SCB block you have initialized for communication with capsense Tuner?
You should make sure that you have connected the FTDI USB to UART converter pins to the UART pins initialized for capsense tuner.
Can you also make sure that your FTDI converter is working as expected by connecting the tx and rx pin together and checking if there is readback happening over a terminal like tera term or putty when you press any key on your keyboard?
Can you also please let me know the PSoC evaluation Kit you are using?
Warm Regards
Alen
AlenAn14
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Warm Regards
Alen
