Dears,
I'm using CY8CKIT-062-WIFI-BT.
If I erase the flash with Cypress Programmer and read it, I can see that the hex file is filled with 0x00.
Generally, I know that flash becomes 0xFF after erase, but PSoC6 becomes 0x00?
I wonder what (0x00 or 0xFF) to fill in the space between the booloader and the application when using the hex2bin utility.
YS
PSoC 6 MCU
In the case of PSoC 6, the Flash erase operation causes the flash content to change to 0x00
You can use Cy_Flash_EraseRow function to erase any particular row in PSoC 6 flash
Best Regards
Ekta
Best Regards
Ekta
Hi Ekta,
Thanks for your reply.
YS
