PSoC™ 6 Forum Discussions
YSJE_3566666
50 questions asked 25 replies posted 100 sign-ins
Dears,
I'm using CY8CKIT-062-WIFI-BT.
If I erase the flash with Cypress Programmer and read it, I can see that the hex file is filled with 0x00.
Generally, I know that flash becomes 0xFF after erase, but PSoC6 becomes 0x00?
I wonder what (0x00 or 0xFF) to fill in the space between the booloader and the application when using the hex2bin utility.
YS
Ekta
Moderator 250 solutions authored 100 likes received 250 sign-ins
Hi @YSJE_3566666
In the case of PSoC 6, the Flash erase operation causes the flash content to change to 0x00
You can use Cy_Flash_EraseRow function to erase any particular row in PSoC 6 flash
Best Regards
Ekta
Ekta
Hi @YSJE_3566666
Best Regards
Ekta
YSJE_3566666
Hi Ekta,
Thanks for your reply.
YS
