The installation instructions of the ModusToolbox say that if you have a custom path you need to edit the environmental variables location from the environmental dialog.
How do I find the Environment Variables dialog? I've looked at all the dropdowns such as File, Edit, Navigate, etc...
I've gone through all the properties of each item I can right click on.
Hi @sensorSentinel,
I believe this is referring to your system variables and not from within the Eclipse IDE. You could try searching for environment variables in Windows search or try running the attached bat script. This should help with your issue.
Rakshith M B
Hi @sensorSentinel,
Rakshith M B
