pschlosser
First like given 5 questions asked 5 replies posted
Device: CY8C6144LQI-S4F12
IDE: IAR version 9.32.2.57414
Hello, we are having an issue in the cypress initialization code. The call tree is:
cybsp_init->init_cycfg_all->init_cycfg_system->init_cycfg_power-> Cy_SysPm_LdoSetVoltage->Cy_SysPm_WriteVoltageBitForFlash
In the last function (Cy_SysPm_WriteVoltageBitForFlash) we are getting an endless loop here:
while (Cy_IPC_Drv_IsLockAcquired(ipcSyscallBase))
/* Polls whether the IPC is released */
For some reason it is getting stuck in the while loop.
More mysteriously it does not get stuck in Debug mode, it only gets stuck in Release mode. I tried setting Optimization to None and it still happens.
Does anyone have any ideas.
sujatapatil
10 likes received 100 sign-ins 25 solutions authored
Hi ,
I am extremely Sorry for delayed response .
I believe this deadlock is on CM4 .  Can you please  send snippet of code on CM0 until you enable CM4 to help you better.
sujata
sujatapatil
Hi ,
I have not heard from you since my response on 4 May 2023. I assume that this is because the issue is resolved and you are busy with other important work.
If, however, the issue is not resolved, please do let me know and I shall work with you to ensure that the issue is resolved.
I will wait for another two days to hear from you. If I do not hear from you, I shall go ahead and close this case.
You can always reopen this case or create a new case for any other issue. We will be happy to help you in resolving your issues.
Thanks and Regards,
sujata
sujatapatil
Hi ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
sujata
