Hi, Sir.
I'm starting to bring up the customer board that cy8ckit_64b0s2_4343w. But when I change to another example, ex: from hello world to Blinky LED, I always need to re-provision it again. So, may I have a method to skip it?
Hugh
Hi Hugh,
Can you please let me know if you are using the same policy or if you are updating the policy file? If in case you are using the same policy file, you can copy the keys and the policy directory from the original code example and place them in the newer example. This way you will be using the same policy and the image signing will use the same keys. Can you please let me know if this works?
Rakshith M B
Hi Hugh,
Rakshith M B
