PSoC™ 6 Forum Discussions
GrCa_1363456
First comment on KBA First comment on blog 250 sign-ins
Which Infineon MCUs support Microsoft Azure RTOS ?
Greg
Ekta
250 solutions authored 100 likes received 250 sign-ins
Hello @GrCa_1363456
Hello @GrCa_1363456
You are correct ThreadX RTOS is now Azure RTOS ThreadX.
Please refer to this link for the list of supported MCUs: https://docs.microsoft.com/en-us/azure/rtos/overview-rtos (under the Supports most popular architectures section)
I will check internally to see if we have any code examples for the same and get back to you if I could find one.
Best Regards
Ekta
GrCa_1363456
For Clarification, I now understand that Azure RTOS was previously called ThreadX. I also understand Azure OS is NOT a requirement to connect to Azure Cloud. If my understanding is incorrect, please clarify the relationship between those three item of code: Azure RTOS, ThreadX and Azure Cloud.
I see there has been at least one side project utilizing ThreadX on a PSoC 6 per “Cypress and Express Logic collaborate to implement ThreadX on PSoC 6 MCUs!” @ https://community.infineon.com/t5/Resource-Library/Cypress-and-Express-Logic-collaborate-to-implemen...
I would like to understand which other Infineon MCUs support Azure RTOS or ThreadX, ideally with code examples or demos.
Greg
Ekta
Hello @GrCa_1363456
Hello @GrCa_1363456
Best Regards
Ekta
Ekta
Hi @GrCa_1363456
I confirmed internally that currently, we do not have any code example on PSoC with ThreadX
Best Regards
Ekta
