Rova_1179706
Hi Community,
After fiddling with shared memory I found my solution using pipes.
It's an easy way to communicate between cores on the PSoC6.
Problem:
I can't find any documentation or AN Aside from the CE223820 example.
I want to learn more about the usage of these pipes.
RodolfoGL
250 sign-ins 5 comments on KBA First comment on KBA
You can start with the Architecture TRM - Inter-Processor Communication (IPC) Chapter, to understand how the pipes can be implemented.
RodolfoGL
GeonaP_26
250 solutions authored 100 solutions authored 50 solutions authored
Adding on to RodolfoG_11​ reply, you can also refer to the PDL documentation available as part of PDL installation folder: C:\Program Files (x86)\Cypress\PDL\3.1.0\doc\pdl_api_reference_manual.html
