TJ
I'd like to wake up from deep-sleep  when counter's capture interrupt event occurs.  I think this interrupt source cannot wake the device from deep-sleep mode, correct me if I'm wrong.  If this is the case, is there a way (trick) to accomplish this?
RodolfoGL
250 solutions authored 250 sign-ins 5 comments on KBA
RodolfoGL
The TCPWM based counter does not run on deep-sleep. You need to use a watchdog timer instead.
If using PDL:
https://cypresssemiconductorco.github.io/psoc6pdl/pdl_api_reference_manual/html/group__group__mcwdt....
If using HAL:
https://cypresssemiconductorco.github.io/psoc6hal/html/group__group__hal__lptimer.html
