I want to use CY8C6145AZI-S3F02 and CY8C6148AZI-S2F44.
1. Should I use miniprog4 instead of miniprog3 for debugging and programming?
2. Should I use modus toolbox? I can't find both devices on PSoC Creator 4.4.
PSoC 6 MCU
>>Yes, you can use miniprog 4
>>Yes, you should use Modus Toolbox
Hi Alakananda,
Thank you for your reply.
Do I have to use miniprog4 because miniprog3 is only pragramming in psoc 6 and doesn't support debugging? I think I've seen these things.
Thanks and Regards,
YS Jeon
Hi Jeon,
Miniprog 3 is not supported by OpenOCD and Miniprog 3 is supported by PSoC Creator and PSoC Programmer. For Modus Toolbox and Cypress Programmer you will have to use Miniprog 4.
Hi Alakananda,
Thank you.
YS Jeon
