hefrc_3803246
I'm trying to use CE219517 on CY8CKIT-06-BLE. After building the project I try to programm the Kit.
Then I get the following error measage:
The selected debug target 'CY8C6347BZI-BLD53' is not compatible with the project's selected device 'CY8C5868LTI-LP039'.
I tryed to change the device in the project to CY8C6347FMI-BLD53 and get the following measage:
How to solve the problem?
ShipingW_81
The target device of CE219517 is the onbaord PSoC 5 LP, and the purpose of this demo is to use PSoC 5 LP monitoring the power consumption of onboard PSoC 63 BLE.
At least you need to PRESS and HOLD SW3 while/before connecting the kit to the computer to enter the bootloader mode of PSoC 5.  Once bootloader mode is entered, use the Bootloader Host along with PSoC Creator to download the cyacd file of CE219517 to PSoC 5 LP.
Please refer to the CE documentation along with the code for details how to use it correctly.
ShipingW_81
Thanks for the quick answer
