Community will be in read-only mode on 25th Sep for 10 hours. Click here for more details
jacintal
10 sign-ins 5 questions asked 5 sign-ins
The following is our understanding of the PSoC 6 datasheet, could anyone check if this is correct?
If Sensor Auto-Reset is enabled, the baseline follows the raw count
If Sensor Auto-Reset is disabled, the baseline will/will not reset depending on the following conditions:
  1. For Noise threshold:
    1. If the baseline < raw count < (baseline + noise threshold), the baseline will reset with the raw count.
    2. If raw count > (baseline +noise threshold), the baseline will not reset.
  2. For Negative Noise threshold and low baseline reset:
    1. If (baseline - negative noise threshold) < raw count < baseline, the baseline will reset with the raw count.
    2. If Raw count < (baseline - negative noise threshold) for a number of samples more than the low baseline reset, the baseline will reset with the raw count.
    3. If Raw count < (baseline - negative noise threshold) for a number of samples less than the low baseline reset, the baseline will not reset.
On top of that, I was wondering if the Noise threshold and Negative Noise threshold are in terms of percentage of the baseline or an absolute number.
Thank you in advance for your help. Have a great day!
PandaS
250 sign-ins 25 likes received 50 solutions authored
Hi @jacintal ,
Your understanding is right and for the Software threshold parameters we calculate them as a percentage of the signal:
Warm Regards
Sobhit
PandaS
Hi @jacintal ,
Warm Regards
Sobhit
