- Email to a Friend
Hi
I am using the DMA Tx and Rx with a UART following code example CE219656.
I am trying to understand the rules for data size and I did tested several size combinations for data_size, src_size and dst_size.
I think the UART buffer is 1-byte, but the UART functions are defined as 4-bytes.
In the code example, the DMA_buffers ("RxDmaUartBufferA and RxDmaUartBufferB") are also 1-byte.
Not all the data/src/dst-size combinations work, very few are sucessful in echoing data to/from the UART, others do not lead to any serial transfer, there is no activity on the serial port. I tabulated the size combinations. I am trying to decipher the size rules that can lead to the expected operation. Any hints ?
thanks
PSoC 6 MCU
- Email to a Friend
I captured the errors and used logic analyzer and signals to monitor the flow and found that:
-For proper operation: RxDMA-SRC and TxDMA-SRC must be 4-bytes.
-If RxDMA-SRC is not 4-bytes, I get "Source bus error"
-If TxDMA-SRC must be 4-bytes, the Tx-DMA does not execute
I think it aligns with your comment.
thanks a lot
- Email to a Friend
Every access to a peripheral FIFO has to be 32-bit, even if the FIFO is 8-bit width.
So in your case, the RxDMA source address and TxDMA destination address need to be all WORD.
- Email to a Friend
thanks a lot
