Hello, I have question about DMA_UART_Tx, I'm using Psoc6 WIFI-BT Pioneer Kit.
Is there an API or register to determine the status of DMA_UART_Tx?
This is to send it again after the transfer is over.
regard. Psoc_Student
Hi @psoc_student ,
You can use the API Cy_DMA_Channel_GetStatus() and check if the transmission is complete or not for the Tx channel. The same one is used in the interrupt ISR of the DMA as well ( where you can also keep a flag to monitor for transmission completion)
Hope this helps.
Warm Regards
Alen
Hi @psoc_student ,
Hope this helps.
Warm Regards
Alen
do you have compiling errors of core_http_config.h: no such file or directory? thanks.
