Hello, I am trying to extract various logs using UART-DMA Tx.
For example, you can send a string, such as "Hello," send a hex value, or send a float, int value.
I can match the character, but I don't know how to apply the size of the buffer that changes every time I send it to DMA.
I attached what I used in the project below. Please give me your opinion on how to modify it.
regards.
Psoc_student
ps. I'm using Psoc6 Pioneer Kit and MTB
Hi:
1. You can Cy_DMA_Descriptor_SetNextDescriptor to set the next dma configuration, that include your requirement about size.
* Function Name: Cy_DMA_Descriptor_SetNextDescriptor
* Sets a Next Descriptor for the specified descriptor.
* Based on the descriptor type, the offset of the address for the next descriptor may
* vary. For the single-transfer descriptor type, this register is at offset 0x0c.
* For the 1D-transfer descriptor type, this register is at offset 0x10.
* For the 2D-transfer descriptor type, this register is at offset 0x14.
* \param descriptor
* The descriptor structure instance declared by the user/component.
* \param nextDescriptor
* The pointer to the next descriptor.
* \funcusage
* \snippet dma/snippet/main.c snippet_Cy_DMA_Descriptor_SetterFunctions
void Cy_DMA_Descriptor_SetNextDescriptor(cy_stc_dma_descriptor_t * descriptor, cy_stc_dma_descriptor_t const * nextDescriptor)
switch((cy_en_dma_descriptor_type_t) _FLD2VAL(CY_DMA_CTL_TYPE, descriptor->ctl))
case CY_DMA_SINGLE_TRANSFER:
descriptor->xCtl = (uint32_t)nextDescriptor;
break;
case CY_DMA_CRC_TRANSFER:
case CY_DMA_1D_TRANSFER:
descriptor->yCtl = (uint32_t)nextDescriptor;
break;
case CY_DMA_2D_TRANSFER:
descriptor->nextPtr = (uint32_t)nextDescriptor;
break;
default:
/* Unsupported type of descriptor */
break;
zhichao
Hi:
* \param descriptor
* \funcusage
break;
break;
break;
default:
break;
zhichao
