In the PSoC6 Programming Specifications (Rev L), Section 5, "Step 1.A Acquire Chip" pseudocode there is a step to set the TEST_MODE bit in the TST_MODE_SRSS register.
// Enter CPU into Test Mode
// Set TEST_MODE bit in TST_MODE SRSS register
WriteIO (SRSS_TST_MODE, SRSS_TST_MODE_TEST_MODE_MSK);
Later this bit is checked:
// Check TEST_MODE bit is set
ReadIO (SRSS_TST_MODE, OUT dataOut); if ((dataOut & SRSS_TST_MODE_TEST_MODE_MSK) == 0) return FAIL;
I can find no details about where this SRSS_TST_MODE (or TST_MODE_SRSS) register is located, or how to construct the SRSS_TST_MODE_TEST_MODE_MSK mask.
The only lead I've found is that the PSoC4 had SRSS (System Resource) registers, it appears.
I have didn't see anything related in the PSoC 63 Architecture TRM, nor in the Register TRM. Searching the broader internet, and ARM resources have not helped so far.
- What are the address and definition for the TEST_MODE bit and the register that contains it?
- In what reference will I find this information?
The information about the register and mask bit I can find is in the Figure 5-4 flow chart of the Acquire chip step.
Set Test Mode bit in TST_MODE reg.
WriteIO(0x40260100,0x80000000);
