I am trying to use the notificationlogger from the C# cysmart API to analyses the log out of my PSoc6 BLE prototyping kit.
Firstly I had the error message saying "Not a valid CySmart dongle!"... By looking a bit into the forum I found the solution to solve this : replace the .dll files with the ones from the current CySmart application (version 1.3).
Once done, I have another issue : The application fall into the "stop mode" and the following message is displayed :
"It is impossible to load the file or the assembly 'cybledonglecommunicator, Version= 1.3.0.8, Culture=neutral, PublicKeyToken=null' or one of its dependencies "
How can I fix it ?
Thank you in advance for your help,
ThDe_4683671
PSoC 6 MCU
Solution found :
I had to change the plateform configuration in x86 (instead of "any CPU")
Solution found :
