jingdadad
5 sign-ins First question asked First reply posted
I want to download programs using cyprogrammer, but the UI interface is gray and cannot be linked. I used a different connector. Should I use the specified connector, such as Kitprog3
Sidramesh_S
250 sign-ins 100 replies posted 25 solutions authored
Hi @jingdadad ,
What do you mean by you want to use a specified connector?
Can you please tell me which board you are using ? Are you connecting Kitprog USB to PC ?
As soon as you connect the Kitprog USB to the PC,you will able to see the Board name in Probe/kit section.
Thanks and regards,
Sidramesh
Sidramesh_S
Hi @jingdadad ,
Thanks and regards,
Sidramesh
Vison_Zhang
First comment on KBA 750 replies posted 250 sign-ins
Cypress Programmer can only support Miniprog4 or Kitprog3, TT-bridge should be used with PSoC Programmer
