I had to enable the continuous scanning myself in HAL library to get the ADC running continuously.
I have modified the library mtb_shared\mtb-hal-cat1\latest-v1.X\COMPONENT_CM4\source\cyhal_adc.c
in function cy_rslt_t cyhal_adc_configure(cyhal_adc_t *obj, const cyhal_adc_config_t *config)
Line 1103:
if(config->continuous_scanning)
obj->continuous_scanning = true;
obj->conversion_complete = false;
Cy_SAR_StartConvert(obj->base, CY_SAR_START_CONVERT_CONTINUOUS);
Before it was like shown below:
Line 1103:
if(obj->continuous_scanning)
BR,
Gintaras
PSoC 6 MCU
- ADC HAL
- modustoolbox
Hi Gintaras,
Thanks for reporting the issue. Let's check this at our side and get back to you.
Vasanth
Hi Gintaras,
Could you confirm whether the following code snippet works at your end?
This snippet shows how to run the ADC in continuous mode and process results as each scan completes.
Vasanth
This issue is resolved in the latest PDL.
Vasanth
