Device is CYBLE-416045-02, sometimes two consecutive I2C transactions fail. Happens with (Write then read) and (Write then Write) cases.
Pseudo code:
cy_stc_scb_i2c_master_xfer_config_t transfer;
uint8_t writeBuffer[1UL] = { subAddress };
transfer.slaveAddress = i2cAddress;
transfer.buffer = writeBuffer;
transfer.bufferSize = 1;
transfer.xferPending = true; /* Do not generate Stop
Cy_SCB_I2C_MasterWrite(SCB1, &transfer, context);
xSemaphoreTake(i2c_sem);// wait for CY_SCB_I2C_MASTER_WR_CMPLT_EVENT callback
Cy_SCB_I2C_MasterRead(); //returns CY_SCB_I2C_MASTER_NOT_READY
If CMPLT_EVENT was received, how can a master not be ready ?
I found if I wait 20uS after a MASTER_NOT_READY, it works. But I cannot explain why I need to waste that time.
Hi @Panometric ,
Can you please let us know the pseudo code for this?
Also, is 20uS an absolute figure or have you tried with a range of wait time? This will help us understand the issue at the device level.
Aashita
xSemaphoreTake(i2c_sem) is just the interrupt and callback.
void I2C_Isr(void)
Cy_SCB_I2C_MasterInterrupt(SCB6, t&i2cContext));
void I2C_Callback0(uint32_t events)
BaseType_t xHigherPriorityTaskWoken;
// Unblock the task by releasing the semaphore
// only if I2C master read or write is completed
if((events & CY_SCB_I2C_MASTER_WR_CMPLT_EVENT)
|| (events & CY_SCB_I2C_MASTER_RD_CMPLT_EVENT))
xSemaphoreGiveFromISR(i2c_sem, &xHigherPriorityTaskWoken);
portYIELD_FROM_ISR(pdTRUE);
20uS seems to be enough with my bus running at 340 Khz, but not enough at 100 Khz.
@Aashita_Raj can you follow up on this?
@Aashita_Raj It has been one month without a resolution. Why would the callback get CY_SCB_I2C_MASTER_WR_CMPLT_EVENT yet after that happens, the next call gets CY_SCB_I2C_MASTER_NOT_READY ?
