KhoaNguyen
50 sign-ins 10 likes given 5 replies posted
Hello community!
I have a project that reads ML8511 + BME280 + PSoC 6 BLE sensors
Previously when I only had the ML8511 sensor, I could connect BLE and send data via Android APP!
But after adding the BME280 sensor to the project, the BLE connection error occurred!
I think the problem is with my code!
I have attached my project! Hope everyone can take a look and help me revise this project!
Thank!.
ADSW
250 sign-ins 50 solutions authored 25 likes received
Hello @KhoaNguyen ,
From your code, at least you need to call Cy_BLE_ProcessEvents() once in 20ms ( advertising interval ).
Instead of using do-while, you can use conditional-if to check the status of sensor BME and decrease the delay from 1000ms to 5.
From line 170 in main_cm4.c
//BME280
if( getTick() - bme_tick >= 500)
            error = BME280_ReadStatusRegister(&status_reg);
            if (error == BME280_OK && ( (status_reg & 16) == 0))
                error = BME280_ReadData(&bme280, BME280_ALL_COMP);
                if (error == BME280_OK)
                    P = ((float) bme280.data.pressure) / 100 ;
                    T = ((float) bme280.data.temperature)/ 100;
                    H = ((float) bme280.data.humidity) / 1024.0 ;
                    sprintf(buf_txt,(const char*)("Pressure:    %shPa   \t\r\n"), ftoa(P,strF,2));
                    UART_PutString(buf_txt) ;
                    sprintf(buf_txt,(const char*)("Temperature: %s*C    \t\r\n"), ftoa(T,strF,2));
                    sprintf(buf_txt,(const char*)("Humidity:    %s      \t\r\n"), ftoa(H,strF,2));
                else
                    UART_PutString("Error: ");
                    switch(error)
                        case(BME280_E_DEV_NOT_FOUND):
                            UART_PutString("BME280_E_DEV_NOT_FOUND\r\n");
                        break;
                        case(BME280_E_NULL_PTR):
                            UART_PutString("BME280_E_NULL_PTR\r\n");
                        break;
                        case(BME280_E_INVALID_LEN):
                            UART_PutString("BME280_E_INVALID_LEN\r\n");
                        break;
                        case(BME280_E_COMM_FAIL):
                            UART_PutString("BME280_E_COMM_FAIL\r\n");
                        break;
                        case(BME280_E_SLEEP_MODE_FAIL):
                            UART_PutString("BME280_E_SLEEP_MODE_FAIL\r\n");
                        break;
                        case(BME280_E_NVM_COPY_FAILED):
                            UART_PutString("BME280_E_NVM_COPY_FAILED\r\n");
                        break;
                    BME280_Reset(&bme280);
            else
                UART_PutString("BME280 is missing !\r\n");
            bme_tick = getTick();
        CyDelay(10);
warm regards,
ADSW
MuhammadNanda_K
250 sign-ins 250 replies posted 50 likes received
Hello @KhoaNguyen ,
I just assigned to your thread.
To be more clarify:
  1. Is your sensor data is already correct if you print that in serial terminal ?
  2. Is your BLE advertising (listed in the mobile apps) ?
It is because after trying your code, it is not listed in apps.
I am still checking on my side.
Meanwhile, please kindly give more information as per my questions.
Thank you and regards,
Muhammad Nanda
ADSW
Hello @KhoaNguyen ,
//BME280
                else
                    switch(error)
                        break;
                        break;
                        break;
                        break;
                        break;
                        break;
            else
        CyDelay(10);
warm regards,
ADSW
