Connect to hidden ap (without SSID) using modus tool box
vim_2255711
5 sign-ins 5 replies posted First question asked
Framework MTB SDK
Board:PSoc 62S2
I tried connect to hidden ssid  by giving only mac address, security type and channel number and SSID len as with zero len and SSID empty string, here BSSID is hard coded for test purpose and made SSID to empty explicitly.
I Used
whd_wifi_join_specific to  join, in this API I commented SSID length sanity check.  after using this  am not able connect to hidden SSID,
whd_wifi_join_specific: set_ssid result (err 0); left network
whd_wifi_join_wait_for_complete: not ready to transceive (err 33555457); left network
Function whd_wifi_join_specific failed at line 1677 checkres = 33555457
Failed to join AP [33555457]. Retrying...
IN whd_wifi_join_specific
but when I change this SSID as  active network in AP, am able to connect.  Please let me know if am missing something.
@vsubbiah
Aditi_B
500 replies posted 5 questions asked 250 replies posted
Is it possible to provide your code example to reproduce the issue in our setup? Also, have you enabled debug macros -
define WPRINT_ENABLE_WHD_ERROR
define WPRINT_ENABLE_WHD_DEBUG
If not, please enable these and provide the debug prints to better understand the issue. Please provide the debug call stack as well to get the exact function which is failing.
Aditi
Aditi_B
Aditi
