Framework MTB SDK
Board:PSoc 62S2
I tried connect to hidden ssid by giving only mac address, security type and channel number and SSID len as with zero len and SSID empty string, here BSSID is hard coded for test purpose and made SSID to empty explicitly.
I Used whd_wifi_join_specific to join, in this API I commented SSID length sanity check. after using this am not able connect to hidden SSID,
whd_wifi_join_specific: set_ssid result (err 0); left network
whd_wifi_join_wait_for_complete: not ready to transceive (err 33555457); left network
Function whd_wifi_join_specific failed at line 1677 checkres = 33555457
Failed to join AP [33555457]. Retrying...
IN whd_wifi_join_specific
but when I change this SSID as active network in AP, am able to connect. Please let me know if am missing something.
@vsubbiah
Is it possible to provide your code example to reproduce the issue in our setup? Also, have you enabled debug macros -
