echonng
5 questions asked 25 sign-ins First solution authored
hi, i am new to modus toolbox. How can i  do the setting to compile my code in c++11 ? Does modus toolbox support it?
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @echonng ,
I tried this setting in CXXFLAGS = -std=c++11 in ModusToolbox and tried the #include <vector> in main.cpp and the same build for me without any errors .
I am using
ModusToolbox 2.4 which uses GCC version 10.3 by default, hence it supports c++ standards 11, 14 and 17 and you can specify the same in CXXFLAGS macro to use.
Can you please let me know which version of ModusToolbox you are using?
Also, if possible, can you please share your project as a zip file here so I can test the same on my side?
Warm Regards
Alen
AlenAn14
Hi @echonng ,
You can create a c++ project in ModusToolbox .
Can you try following the solution in this thread to do the same.
Let me know if you face any difficulty in the same.
Warm Regards
Alen
echonng
hi, i am still not able to compile the codes.. it shows me error message below:
fatal error: vector: No such file or directory
26 | #include <vector>
The codes need to be compiled in c++ 11...
1) i have included in the makefile. but still have error above..
CXXFLAGS += -std=c++11                         # Use C++11 standard
2) How to check if the modus toolbox compiler supports c++ 11 ?
3) Any alternative IDE for PSOC which supports c++ 11 ?
AlenAn14
Hi @echonng ,
I am using
Warm Regards
Alen
echonng
hi Alen,
Thanks for the confirmation. I am currently using ModusToolbox 2.4.
I found the issue of the compiler not locating the vector file happens when the e.g  #include <vector> declared/used in the  .hpp file (C++ header file). It's not an issue if #include <vector> is used in .cpp.
Is there a quick fix to this ?
AlenAn14
Hi @echonng ,
I tried creating the .hpp header file as you mentioned and it's building successfully for me.
The main.hpp is included in the main.cpp file.
Can you please let me know if you are doing anything else different or share your project with me if you are still facing this issue so I can check it out on my side?
Warm Regards
Alen
echonng
hi Alen,
Thanks for the verification. I re-installed the modustoolbox.
I've managed to get the codes compiled now.
Thanks for your support!
AlenAn14
Hi @echonng ,
Glad your query is resolved.
Please feel free to post any queries or issues you may have on Infineon products in the community and we will be happy to help.
Warm Regards
Alen
