Hello, community!
I have a 128x64 pixel graphic LCD panel with a ST7290 controller and I want to connect it to a PSoC 6. I understand that there are voltage levels, but I plan to use logic voltage converters to get around the problem. I plan to use serial communication mode, so that 3 GPIOs should be enough.
I would like to know if anyone has done this before, so that I could get a code example to start off. Anyone?
Thank you very much.
Júlio Tanomaru, from Brazil
PSoC 6 MCU
Hi @tanomaru ,
We presently do not have a code example which involves the usage of logic voltage converter. However, you can refer this code example here : https://www.cypress.com/documentation/code-examples/ce223726-psoc-6-tft-display-interface-emwin-grap... to get started with the flow of the code and interfacing an LCD with PSoC 6.
We have few LCD code examples, developed for PSoC 3, PSoC 4, PSoC 5LP : https://www.cypress.com/documentation/code-examples/ce195291-character-lcd-horizontal-bar-graph-psoc... which you can follow, for debugging your issues.
You can also refer to the datasheet of ST7290 graphical LCD module for more information : https://components101.com/asset/sites/default/files/component_datasheet/ST7290%20Graphical%20LCD.pdf . Also, can you please elaborate your application more, so that we can help you with the proper solution?
Please let us know in case of further queries.
Aashita
Hi @tanomaru ,
Aashita
Thank you for the reply, Aashita. I will read the references you indicated. As for my application, the main purpose at the moment is to exhibit simple debugging/monitoring information using a low priority FreeRTOS task. As I said, I have the GLCD lying around and thought it would be nice to use it. Thanks again.
Júlio Tanomaru
