JeHu_3414236
10 likes received First like received
I am using the CapSense Tuner I2C project but I cannot get any touch detection on my board.  The I2C connection is ok and it is reading 154pkts/s.  The graph in the tuner always reads no activity.  When I load my own application with SmartSense Full Auto Tune, I can detect slider and button press but the accuracy is bad.  If I try to enable Full Auto Tune in the Tuner project, it fails on connection and says checksum mismatch.  Does anyone know what I should change in the tuner project so I can see some activity?
Which CapSense Tuner I2C project and kit are you using?
Manual tuning may require extra tuning according to different kits or customer boards.
Ryan
JeHu_3414236
I got the tuner to work on my own project using full auto tune.  I'm still not sure why I see 0 activity using the I2C demo project.  If the results of auto tune aren't good, is there a guide for modifying the tuning settings?
Ryan
I am using CE222827_PSoC6_CapSense_Tuner with project name CapSense_Tuner_EZI2C01 from the examples installed in PSoC Creator 4.2.  The main_cm4.c header version says 1.10.  I will work with my local FAE for manual tuning.  Thanks.
