I have successfully programmed and unprogrammed PSoC demos on the CY8CPROTO-062-4343W boards but once I program an aws_demo the board is bricked. The board runs the firmware but cannot be reprogrammed. I have tried this on 3 different boards with the same results. This thread discussed the same problem without providing a solution. BTW I have updated the adapter firmware tried the Cypress programmer as well.
Any help will be appreciated since I have had to order 3 new boards.
Log of errors
Open On-Chip Debugger 0.10.0+dev-4.1.0.1058 (2020-08-11-03:45)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
adapter speed: 2000 kHz
adapter srst delay: 25
adapter srst pulse_width: 25
** Auto-acquire enabled, use "set ENABLE_ACQUIRE 0" to disable
cortex_m reset_config sysresetreq
Info : Using CMSIS loader 'CY8C6xxA_SMIF' for bank 'psoc6_smif0_cm0' (footprint 14672 bytes)
Warn : SFlash programming allowed for regions: USER, TOC, KEY
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: FW Version = 2.0.0
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : KitProg3: FW version: 2.10.878
Info : KitProg3: Pipelined transfers enabled
Info : VTarget = 3.325 V
Info : kitprog3: acquiring the device...
Error: kitprog3: failed to acquire the device
Info : clock speed 2000 kHz
Info : SWD DPIDR 0x6ba02477
Error: Failed to read memory at 0xe000ed00
Polling target psoc6.cpu.cm0 failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Examination failed, GDB will be halted. Polling again in 300ms
Info : starting gdb server for psoc6.cpu.cm0 on 3333
Info : Listening on port 3333 for gdb connections
Info : starting gdb server for psoc6.cpu.cm4 on 3334
Info : Listening on port 3334 for gdb connections
** Device is not present in the UDD
Error: Failed to read memory at 0x16000000
Error: mem2array: Read @ 0x16000000, w=4, cnt=1, failed
Error: Failed to read memory at 0x16002004
Error: mem2array: Read @ 0x16002004, w=4, cnt=1, failed
Error: Invalid FlashBoot: High version word of Flash Boot is zero
Error: Failed to read memory at 0x402020c4
Error: mem2array: Read @ 0x402020c4, w=4, cnt=1, failed
Error executing event examine-end on target psoc6.cpu.cm0:
/Applications/ModusToolbox/tools_2.2/openocd/bin/../scripts/mem_helper.tcl:6: Error:
in procedure 'program'
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 279
in procedure 'cy_get_set_device_param' called at file "/Applications/ModusToolbox/tools_2.2/openocd/bin/../scripts/target/mxs40/psoc6_common.cfg", line 129
in procedure 'show_chip_protection' called at file "/Applications/ModusToolbox/tools_2.2/openocd/bin/../scripts/target/mxs40/cy_get_set_device_param.cfg", line 164
in procedure 'mrw' called at file "/Applications/ModusToolbox/tools_2.2/openocd/bin/../scripts/target/mxs40/cy_get_set_device_param.cfg", line 118
at file "/Applications/ModusToolbox/tools_2.2/openocd/bin/../scripts/mem_helper.tcl", line 6
Info : AP write error, reset will not halt
Polling target psoc6.cpu.cm4 failed, trying to reexamine
** Program operation failed **
srst_only separate srst_gates_jtag srst_open_drain connect_deassert_srst
Examination failed, GDB will be halted. Polling again in 700ms
Error: DP initialisation failed
Info : psoc6.dap: powering down debug domain...
Warn : Failed to power down Debug Domains
Hi Kobus,
We confirmed that the amazon-freertos 201910-MTBAFR1951 is setting some internal bits in the SFlash incorrectly, causing the issue you observed.
The newest release, amazon-freertos 202007-MTBAFR41 fixed this issue.
Here is the list of releases:
Tags · cypresssemiconductorco/amazon-freertos · GitHub
We are still working on a method to recover the boards flashed with the old version. If we find a way to do so, we will post here.
