Can't select CY8C6244AZI-S4D93 in PSoC Creator 4.4
Brent
I can't find the "CY8C6244AZI-S4D9" at the "Select device" window in PSoC Creator 4.4
Can I have any method to use "CY8C6244AZI-S4D9" with PSoC Creator 4.4?
Aashita_R
50 likes received 100 solutions authored 250 replies posted
Hi @Brent ,
PSoC Creator only supports the PSoC6A-BLE2 base die. It does not support the PSoC 6-A2M (*-S2*), PSoC 6A-512k (*-S3*), or the PSoC 6A-256k (*-S4*). The referenced MPN is part of PSoC 6A-256k. To use the full range of PSoC products, we recommend using ModusToolbox™ Software - Infineon Technologies
We encourage our customers to use ModusToolbox as we’re only supporting PSoC Creator in maintenance mode. Please feel free to add here in case of any further query.
Aashita
Aashita_R
Hi @Brent ,
Aashita
Brent
Thank you, Aashita!
I will try with ModusToolbbox.
Aashita_R
Hi @Brent ,
Sure! Please go ahead with ModusToolbox and let us know in case you need any help with the same.
Aashita
