Rova_1179706
I would have expected the IDE to generate the macro's for the pin-instance.
Is this feature removed for the PSoC 6?
This is my first time working with the PSoC 6.
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
For PSoC 6 GPIO access function was changed to
Cy_GPIO_Write(Pin_PORT, Pin_NUM, value)
Please try and expand Cy_GPIO to see available variants.
It is also recommended to read
Differences Between PSoC 4 and PSoC 6 MCU Software Architecture - KBA220606
And also take a look at other example projects accessible from the menu "File > Code Example..."
moto
MotooTanaka
Level 9
Level 9
moto
