TaTa_2447651
First solution authored 25 replies posted 10 replies posted
I am developing BLE devices using PSoC63.
I have created a project with BLE components in place using PSoC Creator.
I would like to export this project to EWARM.
PSoC Creator generates an archive file of the BLE stack when you use BLE components.
Can I use this archive file when I export to EWARM?
Best regards.
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi TaTa_2447651​,
You should be able to export the PSoC Creator project to IAR Embedded Workbench. Please refer to the Generating PSoC 6 Files for 3rd Party IDEs PSoC Creator Help Topic. Ensure that the IAR EW version you have supports PSoC 6 devices.
You can also refer to this discussion - PSOC Creator | Export PSOC Program to an IDE
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi TaTa_2447651​,
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Thanks for the answer.
Are you saying that a PSoC Creator project with BLE components in place can be exported to EWARM?
Best regards.
Hi TaTa_2447651,
Yes you should be able to export PSoC Creator projects with BLE to IAR.
Rakshith
Thanks and Regards,
Rakshith M B
