Max
5 questions asked 10 sign-ins 5 replies posted
Hello everyone,
I work on a project on CYBLE-416045-02 module. I have start with demo project to use BLE. For this moment all woked great.
i have create a new task which print a message every 10 secondes.
I program my module all work great, all task initialized, Ble advertisement OK and my new task work great with a message every 10s.
At this moment, activate advertisement and i connect my module and my smartphone application.
After connexion succesfull, all continue to work great.
After this test, i quit my smartphone application and at this moment my new task print none message and i don't see any disconnect message on my console.
Do you have any advice or idea about this problem ?
Max
Max
Hello everyone,
I have found the problem,
void static DisconnectEventHandler(void)
    /* Variable used to store the return values of RTOS APIs */
    BaseType_t rtosApiResult;
    requestHtsIndication = false;
    /* Turn off the Orange LED and blink the Red LED once to
       indicate disconnection*/
    status_led_data_t statusLedData =
       .orangeLed = LED_TURN_OFF,
       .redLed    = LED_BLINK_ONCE
    rtosApiResult = xQueueSend(statusLedDataQ, &statusLedData,0u);
    if(rtosApiResult != pdTRUE)
        Task_DebugPrintf("Failure! : BLE - Sending data to Status LED queue",
                          0u);
    /* Request Temperature Task not to send any data */
   // notification_command_t notificationCommand = RESET;
    //xQueueOverwrite(notificationMessageQ, &notificationCommand);
    notification_message_t notificationMessage;
    notificationMessage.command = RESET;
    xQueueReset(notificationMessageQ);                              //reset queue to initial state empty
    xQueueSend(notificationMessageQ, &notificationMessage,0u);      //sendMessage
You can see in comment the 2 precedentes lines and below the 4 new lines.
The main problem come from xQueueOverwrite which work with only a 1 length queue. After different tests, i saw when i set my queue for notificationMessageQ to 1 my disconnexion worked. So i change my xQueueOverwrite to XQueueSend and i added a xQueueReset to be sure that the only element on my queue was Reset.
Max
To complete my informations, i have used CySmart to test disconnect. And i have the same problem. After a click on Disconnect, my module freeze, no message print and no new advertisment available.
Max
PratikshaV
5 likes given 250 sign-ins 50 solutions authored
Hi @Max
Please can you share the Air logs and your project so that  we can understand the issue better.
If using Modustoolbox you can refer below code example :
https://github.com/Infineon/mtb-example-psoc6-ble-battery-level-freertos
Thanks & Regards
Pratiksha V
Max
Hello everyone,
                          0u);
