I am creating a project to utilize the ADC of the PSoC6 as a thermistor circuit and the CapSense separately. When I try to generate the application I get analog pin errors. Can the PSoC6 only support either the ADC or CapSense at once? And if so does anyone have a recommendation on easy to interface external ADC's?
PSoC 6 MCU
Hi @theaaronm
You can use the ADC feature built-in to CapSense component to share the resource between CapSense and ADC. To achieve this, go to CapSense configurator > ADC tab and select the number of channels and the resolution of the ADC that is needed -
Hari
Hi @theaaronm
Hari
