PSoC™ 6 Forum Discussions
SURYASUNDAR
First like given 50 sign-ins First solution authored
Hi
I was tried to program CY8CPROTO-062-4343W with kitprog3 debugger .It showing some error .Could you please help me to sort out the error. I am attaching the errors showing in eclipse ide.
LeoMathews
100 sign-ins 25 solutions authored 100 replies posted
Hi @SURYASUNDAR
Can you please make sure that the power selection jumper(J3) which is used to select the PSoC 6 MCU’s supply
voltage (P6.VDD) between 1.8 V and 3.3 V is connected between pins 2 and 3? If not, please connect the pins using the jumper and try programming the board again.
Thanks and Regards,
Leo
LeoMathews
Hi @SURYASUNDAR
Thanks and Regards,
Leo
LeoMathews
Hi @SURYASUNDAR ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
