PSoC Creator 4.2 does not give me the option of selecting *any* Target Kit, as the option is greyed out. The CY8CKIT-062-WiFi-BT is connected, and Creator can see an active port (Tools>Bootloader Host...), but the IDE does not recognize the board. The LEDs are solid yellow (LED4) and yellow flashing @ 1HZ (LED2). Holding reset for10 secs make no diff.
Is this b/c I have an early Rev of the board. I saw an older, similar post where Creator 4.2 would not recognize the board b/c it was an early revision, here:
CY8CKIT-062-BLE I can not programming psoc63 chip
or is there something more easily rectified going on.
ispn:39620:1:0
l1:314:1:0
If the onboard KitProg2 function is valid? The active port under Tools>Bootloader Host just guarantees the valid usb-i2c/uart bridge function, not full function of KitProg2.
If you have tried out all what is advised in thread CY8CKIT-062-BLE I can not programming psoc63 chip and it's not effective. You might need do the same to request a replacement from the original purchase channel.
