I've got the CY8CKIT-062-WIFI-BT Pioneer Kit, and was just trying to work through a Bluetooth example (From Alan Hawse's old 'PSOC 6 101' series.) I came up short when trying to add a BLE component to my schematic, however - the IDE says the component is not compatible with the target defice (which in hindsight I guess makes sense, as the kit is named 'BT' not 'BLE'). Is there a compatible Bluetooth component for this eval board?
Hello ,
For CY8CKIT-062-WIFI-BT , please use Modus Tool Box IDE : https://www.infineon.com/cms/en/design-support/tools/sdk/modustoolbox-software/
Anjana
Thanks for the reply, Anjana - unfortunately, I need to also be able to configure UDBs, etc via the PSOC 'Fabric' layer, and to the best of my knowledge, Modus Tool Box still does not support that, is that correct?
Thanks Again
Hi @JiSt_4468101 ,
Can you please give us more details about the project or application that you are building as you want to configure UDB?
So that we can have better idea while suggesting alternative eval board.
Thanks and regards.
Advait.
This thread has been locked due to inactivity for more than 3 weeks. Please create a new thread if you require further support.
Thanks and regards,
Advait.
