a few years back I did this, but I've lost track of where I got the utility. I need to put an image on the display. From my recollection I had to take the image (jpg I think) and run it through a utility that the e-ink manufacturer sent me. I got that information from you folks. Could you provide me the contact information or website for the e-ink manufacturer so I can get this utility again? Many thanks.
Steve
Hi @KC1SA ,
I am dropping a few links that might be useful for you.
- PSoC Creator EmWin CE: https://www.infineon.com/dgdl/Infineon-CE23727_PSoC_6_E-INK_Display_Interface_with_EmWin_Graphics_Li...
- MTB EmWin CE: https://github.com/Infineon/mtb-example-psoc6-emwin-eink-freertos
- https://community.infineon.com/t5/PSoC-6/How-to-Create-a-new-image-on-E-ink-display/td-p/203655
- Although this is with respect to CYW20719, you may refer to the steps involved in interfacing E-INK display with a uC: https://community.infineon.com/t5/Resource-Library/E-ink-Display-interface-with-CYW20719/ta-p/246361
Nikhil
Hi @KC1SA ,
Nikhil
application was what I was looking for. Pervasive Displays keeps the
utility locked up behind a firewall but this doc in the Cypress app note
has an older version of the utility in a Dropbox location. It's what I
needed albeit and older version, it will work.
thanks again.
73,
Steve
*KC1SA*
Exactly what I was looking for. The last link in the answer had a doc with the application that pointed to a dropbox site with the Pervasive Display application I was looking for, albeit an older version, it will work.
Thx.
