HI
I would like to know where can I find psoc 6 modustoolbox examples to use the analog microphone in the board CY8CKIT-028-sense.
I see from the the board documentation that it includes several microphones. two digital and one analog.
I'm interest in processing data from the analog microphone (Vesper VM1010) using a CY8CKIT-062S2-43012. Particularly in capturing sound signal level after the VM1010 has triggered the interrupt signal. Or is the VM1010 meant to be only as a sound trigger on the board to activate the digital to microphones capture the audio?
Apart from he machine learning example in the documentation, do you have any other modustoolbox example that uses this board ?
The board's github repo has a broken link to the Audio codec usage
thanks
Hi @mvpablo,
Find the link to audio codec code example here: https://github.com/Infineon/audio-codec-wm8960
Nikhil
