Can CY8CKIT-002 be used to Flash Code onto CW308T-PSOC62 ( Chip Whisperer Target Board).
Kindly let me know if this is possible.
Thanks and Regards ,
Niharika
PSoC 6 MCU
Hi @niharika ,
Yes, It is possible to flash this board with MiniProg 3 (CY8CKIT-002) using the SWD lines.
Please use the 5 pin connector on the MiniProg 3 to do the same ( make the connections from Miniprog 3 to the board as mentioned in Section 3.2.1 of CY8CKIT-002 MiniProg3 Kit Guide )
MiniProg 3 - > W308T-PSOC62
XRES RST
SDAT SWDIO
SCLK SWCLK
VTARG Vref
<No Connection> SWO
MiniProg3 also supports JTAG which can also be used, but this is supported only through the 10 pin connector which I did not see on this board.
Hope this helps.
Alen
Hi @niharika ,
XRES RST
SDAT SWDIO
SCLK SWCLK
VTARG Vref
<No Connection> SWO
Hope this helps.
Alen
Thank you so much 😄
Glad your query is resolved.
Please feel free to post any queries or issues you may face on Infineon products and we will be happy to help.
Alen
